Planning to do a brake job
Old Jun 14, 2006 | 10:22 PM
Nand12's Avatar
Default Planning to do a brake job
The brakes on my 99 S70 are pretty much shot so I want to do a brake job. In terms of parts, this is what I'm planning on ordering from fcpgroton:
OEM Front Pads
OEM Rear Pads
Zimmermann Front Rotors
Zimmermann Rear Rotors
Brake Cleaner
Brake Pad Grease
Are there any parts that I'm forgetting and do you think this combination will provide good non-squeak braking performance? Thanks a bunch.
Old Jun 14, 2006 | 10:29 PM
Default RE: Planning to do a brake job
You should be fine with that setup that is what we use everyday at work.
Old Jun 17, 2006 | 07:01 PM
Nand12's Avatar
Thanks for the quick reply. I was wondering what the lug nut size is for the base model S70 (no alloy wheels)? Thanks very much.
Old Jun 17, 2006 | 07:22 PM
Do you mean by what size socket on the lugs? If so it is a 19mm.
Old Jun 17, 2006 | 08:45 PM
Nand12's Avatar
Thanks tech!
PaddyG
1998-2000 model year V70
Feb 17, 2014 05:23 PM
jikispqr
Jul 3, 2009 02:34 AM
huzzsaba
Jun 3, 2009 01:01 PM
anovlov
Apr 21, 2009 06:02 PM
68Brick
Canada, Over Seas & Elsewhere
Jan 14, 2008 09:36 PM
