problem with my switch
Old Jul 29, 2007 | 08:17 PM
S70ismyfriend's Avatar
Default problem with my switch
i seem to have encountered a problem with my windown switch on my car the rear passenger side window will roll down and up with the switch on the door but when i use the switch for it on the driver side door it will go down but not up so ik its a bad switch my question is how hard would it be to replace and fix?
Old Jul 29, 2007 | 08:43 PM
Default RE: problem with my switch
To replace is very easy. Using a hook tool pull the switch out of the door panel and replace.
Old Jul 30, 2007 | 02:12 PM
James0013's Avatar
I had the exact same problem with thefront passenger window. Before you buy any new swiches try disconecting the swich and then reconecting it. I sent mine into the shop for a problem with the check strap in the drivers door. to fix this they had to take the internals of the door off. When I got the car back the passenger window swich was working again. I think the conections just get dirty over time.
Old Aug 2, 2007 | 10:15 PM
ok thnks alot ill give it a try
bennyd20
Sep 23, 2011 07:34 PM
edgardlois
May 9, 2008 02:04 PM
davolvogreenguy
Oct 12, 2006 08:38 PM
rzskier
Dec 12, 2005 09:40 PM
