Problems with my 2000 S70
Old Oct 9, 2005 | 02:47 PM
LSU_Mackey's Avatar
Default Problems with my 2000 S70
New To the Board,
Hello All,
I have a 2000 Volvo S70 and I love it. There are a few problems with it now that I need to see about getting addressed.
1) I just noticed my door panels (the plastic around the leather) is peeling off, as in it is completely coming off, and if I pull very lightly it feels as if I can pull the whole thing off.
2) The leather skin on the door, around the handle) is peeling, like it has an air bubble behind it.
3) I do not use Volvo replacement lights and ever since I replaced them the turn signal blinks 2-3x faster than a normal turn signal.
I believe thats it for right now, I hope you guys can help me or tell me what I should do.
Thanks,
Mackey
Old Oct 9, 2005 | 03:38 PM
Default RE: Problems with my 2000 S70
1. do you mean the door panel is like falling into the door?
2. There isn't much you can do besides replace the door panels.I know the dealers used to repair them but not sure if they sell the kit over the counter.
3.Remove the bulbs and check for burnt marks on the bulbs and sockets.
Old Oct 9, 2005 | 06:17 PM
fire2havoc's Avatar
1. You may be able to buy reinforcement molding to hold the panels in place. Can't guarantee its durability, though.
2. Like tech said, not much that can be done. My leather is also cracking and showing signs of serious wear.
3. It may be a problem with the module block that controls your turning signals. Might want a mechanic to check out the wiring and connectivity.
Old Oct 9, 2005 | 09:16 PM
LSU_Mackey's Avatar
Like, the plastic that goes around the leather/speaker/door handle inside the car is pulling off, as if it was glued on, I do not know whats connecting it.
I understand about the leather, I was thinking about popping a small hole in it with a syringe filled with glue then pushing the leather down, dunno if thats smart or not.
Old Oct 9, 2005 | 10:26 PM
The plastic ring around the door handle only snaps in.
The speaker cover should also snap in.
kennedy759
Jul 23, 2013 10:21 AM
BlueCracka
Jan 16, 2013 06:36 AM
BlueCracka
Jan 14, 2013 12:49 PM
adk793
Nov 8, 2009 10:14 PM
Tina_Richards
Sep 27, 2005 10:05 PM
