Rear Shocks Brand Replacement Suggestion & Turbo Gasket?
Old Sep 27, 2011 | 09:55 AM
Meloyler's Avatar
Smile Rear Shocks Brand Replacement Suggestion & Turbo Gasket?
99 S70 T-5 with only 97K miles - I've been told that my rear shocks are leaking - does anyone have a suggestion as to a decent brand of replacement shocks?
Also, is replacing the gasket for the turbo charger a fairly simple procedure overall? I was told that this was leaking a little as well - not badly yet, but I want to get it taken care of quickly for obvious reasons....
Thanks so much!
Old Oct 3, 2011 | 02:51 PM
tomecsi's Avatar
My mechanic says it will take him about 1 hour to do it but 2 hours conservatively. Do you know where to get the turbo seal? Havent had much luck finding it.
As far as shocks/struts go, I just put Monroe on my S70 and I'm happy. Its a 2000 with 164k miles. I guess it just depends on how you drive it.
Old Oct 6, 2011 | 08:06 AM
Meloyler's Avatar
Hi there and yes, I do have a turbo seal from a buddy of mine who works at a dealer in Florida who is sending it to me - it's only about $6.00, so pretty cheap, (& he said it wouldn't take very long at all, but then he knows what he is doing too).
Thanks for the suggestion of Monroe - I'll check into them - sure appreciate it!
Old Oct 6, 2011 | 12:24 PM
Elchopperfreak's Avatar
If you just want comfort and durability go with Boge Sachs, oem for the s70, I found a pair of front ones on ebay for $160.00 with shipping to PR ( front are a lot more expensive)
Check what brand do you have in front.
Bilsteins TC are good a bit firm for our roads.
Monroe sensa trac are "plusher" but if you can change them yourself, some with warranty ( some places lifetime)
On the turbo, which gasket? The oil return one?
I just changed mine and took me about 20 minutes, including the seal that goes into the oil pan.
The oil return gasket is about a buck something, as well as the seal ( I bought them at the local dealer and they had them at $6.00 each, $4.00 with discount)
You will need a long 5.5 mm allen socket to make life simple.
Old Oct 7, 2011 | 08:27 AM
tomecsi's Avatar
Anybody have a link for an exploded parts diagram for the turbo in 2000 S70?
Old Oct 7, 2011 | 12:28 PM
Old Oct 13, 2011 | 09:48 AM
tomecsi's Avatar
Beautiful, thanks! Parts list available?
Old Oct 13, 2011 | 11:52 AM
Google it for the part liat
Which gasket do you neeed?
Have you found the oil leak?
Old Oct 14, 2011 | 10:48 AM
emilys70's Avatar
Will this drawing work for a 99 s70 awd as well?
emilys70's Avatar
Sorry for the thread jack.
Old Oct 14, 2011 | 11:00 AM
If its turbo, yes..
Old Oct 14, 2011 | 11:07 AM
emilys70's Avatar
Thanks much, Elchopperfreak.
Old Oct 14, 2011 | 02:10 PM
tomecsi's Avatar
I havent had a chance to get into it much but standing over the engine looking down, there is a lot of oil buildup where the intercooler feed meets the turbo. There is like a rubber hose coupling there with a lot of oil buildup on it.
Old Oct 14, 2011 | 09:12 PM
I did not have much oil on that area, some gunk, but nothing major, clean that gunk up but first look at the right side of that rubber hose and check for gunk near the plastic tube, theres a rubber hose and the PTC valve, if theres a lot of build up check and clean the PTC valve ( i remember all this cause I had an ongoing thread trying to find out exactly which was the culprit at MVS)
Those are things that you will need to address, no matter what, but if its such as drip as you claim in your original post, I bet is from the return tube under the car, you cant see the leak from above. Let me get a couple shots so you have a better pic.
The turbo oil return tube , gaske and seal ( the round end goes into the oil pan) # 29,30,31
The tube goes underneath the turbo # 14
This is what the turbo oil return looks like without the tube ( remember that its underneath) what you can see from atop are the coolant banjos
umbalaxx
May 31, 2015 12:32 PM
jared..mann
1998-2000 model year V70
Apr 20, 2013 04:33 PM
mandobizar
Apr 22, 2011 01:22 PM
akkevint
Feb 2, 2009 06:45 PM
parrym
Jul 13, 2007 12:51 PM
