relay fan
Old Dec 5, 2015 | 10:12 AM
Marisa Newell's Avatar
Default relay fan
The heat and a/c fan comes on automatically when car is not running..
which drains the battery. Any suggestions
Old Dec 5, 2015 | 02:13 PM
pkrface's Avatar
It is supposed to come on, even if the car is turned off, in warmer weather to dry out the A/C evaporator and ducts, but there is a battery voltage condition in the logic that should not allow it to drain the battery. It is called "afterblow". Other threads here have suggested a stuck relay in that circuitry could cause the issue you are experiencing.
Old Dec 9, 2015 | 10:13 PM
yep - if the s70s are set up similar to my 850, the relay is up front by the top of the radiator.
sleech
Jan 25, 2020 05:07 PM
axelm
Jun 17, 2016 12:24 AM
dads 740 turbo
Oct 24, 2008 06:54 PM
gunnison
Mar 23, 2007 02:51 PM
tmor84
Oct 10, 2006 10:54 PM
