S70 99 Front Oxygen Sensor
Old Oct 28, 2008 | 09:16 AM
Icefire's Avatar
Default S70 99 Front Oxygen Sensor
Is there any good aftermarket one? Even the cut the plug and solder it?
Volvo want near 400$ for the sensor alone while I can see cheap 4 wire at 33$ and Bosch at 96-150$.
Old Oct 28, 2008 | 09:19 AM
Default RE: S70 99 Front Oxygen Sensor
If you want to fix the problem find a Bosch DIRECT fit sensor or you will continue to have problems with the car.
Volvo's have universal ones.
Old Oct 28, 2008 | 10:12 AM
Icefire's Avatar
Looking at it online, I can't find a Direct Fit Bosch for a 99 S70 non turbo B5254S
I'll try a Local volvo for an universal.
Old Oct 28, 2008 | 10:19 AM
My bad I thought it was a turbo. You will need s Denso direct fit sensor.
Click link to one.
http://www.fcpgroton.com/product-exe...ategory_id/170
Old Oct 28, 2008 | 10:24 AM
Icefire's Avatar
Well Bosch just called back, Model 15558 should work as direct fit (4 wire, same plug).
Old Oct 28, 2008 | 10:26 AM
OK cool then.
soduku007
Oct 7, 2019 04:01 PM
habbyguy
Nov 10, 2014 07:01 PM
PMOURASSA
May 20, 2012 12:59 AM
FrankG
Aug 23, 2010 08:48 AM
