S70 Idle/MPG problems
Old Mar 3, 2009 | 07:33 AM
mitch603's Avatar
Default S70 Idle/MPG problems
So i replaced the radiator in my car cuz i bew a hole in the bottom of it. Everythign was replaced correctly. ran fine for about a day and then My car does not idle. It drops below 500 and jumps to about 1200 constantly. I have put in fuel injector cleaner and also 3 tanks of premium gas.
Im also only getting 9mpg as i was geting 24/21.
Not sure whats going on please help me
Old Mar 3, 2009 | 01:54 PM
Reminiscence's Avatar
Does the car shake when it's idle?
Old Mar 5, 2009 | 07:44 AM
mitch603's Avatar
very much so. Its a very hard idle. It kind of jumps. Also i was told it could be the IAC sensor which im hoping not cuz they are expensive
Old Mar 5, 2009 | 03:10 PM
Pretty much everything with Volvo is expensive unfortunately. You can save some by having your own trusted specialist mechanic though. I had this problem a little while ago, and it left me stranded at a parking lot, so watch out and get it taken care of. It sounds very similar to what I had, which was a failing mass air flow sensor. I had mine replaced at Volvo, which charged me $450 with parts and labor. It was steep, but it had to be done. Sounds like that's what it is, but I'm not 100%. Definitely get it checked out though.
wheelsup
Apr 16, 2017 08:47 PM
FourToes
Jun 22, 2015 02:47 AM
ms000
Jan 2, 2015 11:15 AM
yoyoman
Feb 20, 2010 12:50 PM
all4
Aug 9, 2005 03:12 AM
