S70 not starting...
Old Jul 13, 2007 | 02:29 PM
thomaskr's Avatar
Default S70 not starting...
Hi, I have a 2000 S70 with a little over 100k km on the dial.
This morning, after a lot of recent precipitation (we keep it in the driveway outdoors) the car would not start. Symptoms were: turned the key and all warning lights flashed only during startup attempt with clicking noise. No clicking noise from starter motor. Checked the battery, it was fully charged. I used the boost function of my charger to start the car. It started fine. Turned off the car, left charger on for a few minutes anyway. Car proceeded to start without charger boost. Drove car a couple of km, turned off car, it started fine again. My wife took the car, drove around, left it sitting for a while, and it again started fine. After a few hours of sitting in the driveway, it now will not start again, same symptoms.
Weird that the dashlights click and flicker during startup attempt - is there a short? Why would it work after slightly boosting the battery? Is it possibly a moisture problem? (we've been having a lot of rain lately).
Any advice before I take it to be looked at and repaired would be appreciated. Of course, it happened on a Friday ;-)
Old Jul 25, 2007 | 07:28 PM
nsimha's Avatar
Default RE: S70 not starting...
Sounds very, very similar to what I am experiencing (see my recent post). Did you get any suggestions/hints directly?
Thanks
Nick
Old Jul 25, 2007 | 08:04 PM
samadkins29's Avatar
bad alternator?
Old Jul 27, 2007 | 08:35 AM
thomaskr's Avatar
Sorry for the late reply, but it was the battery. I should have known better because EVERY SINGLE European car that I've owned, no matter how good the car (and I've owned a 911) has come with a sh*tty Euro battery that's not made to last. Got one with a 5-year replacement warranty for about $100 and we're back in business.
I didn't have an ammeter, only the volt meter on the recharger - which is what threw me off. With a full voltage indicated, either the battery is completely messed up (which it was) or something in the ignition circuit would be at fault (not a happy prospect).
One little point for all of you who haven't swapped a battery in an S-70: it's a bit funky, without ANY tie-down wires or straps. There's a lip to hold the battery edges down and a plastic clip that snaps on to hold the battery from sliding back and forth. MAKE CAREFUL NOTE of how the clip is attached so you won't get frustrated later. It goes on over the entire plastic holder, not just the battery (if that makes any sense). Typically Volvo, it works like Lego or Tupperware, so once you get the hang of it, you'll love it for life and maybe even try it over a couple of times just because it's kind of fun.
Old Oct 19, 2007 | 07:51 PM
bmanflyer's Avatar
just changed my battery and I am having problems with the plastic clip I thought I had a good idea of how and were it goes but it seems like it will only go toward the end of the tray and then dies not seem very secure like if you hit a small bump it would come loose any suggestions ????? [X(]
Old Oct 29, 2007 | 10:12 AM
thomaskr's Avatar
Sounds like you're either installing the clip wrong or the battery does not have the correct base. It should snap on with the "C" portion holding the battery and the tray together. It will not appear secure if it is on incorrectly.
Old Oct 29, 2007 | 10:22 AM
JimKW's Avatar
I did this once too and could not get the clip on the battery and the tray. My problem was that the battery was just a little bit differnent and it would not go over the lip. Took the battery back and made sure I got the exact match the 2nd time. Had to switch to a different brand at AutoZone.
Old Oct 29, 2007 | 10:16 PM
Flip's Avatar
ORIGINAL: thomaskr
I know exactly what you mean, I had the same problem, went to Autozone found a battery that was compatible with the S70 and worked just fine. The replacement battery wasn't an exact fit, it was actually a bit smaller but the clip has different slots for after market batteries that fit just fine. Just make sure you get one that the store says fits on your vehicle.
Vone
Mar 6, 2014 04:24 PM
jelawman
Jul 1, 2011 10:21 PM
darens67
Jan 25, 2009 05:39 PM
pikey
May 10, 2007 01:34 PM
