soon to be S70 Glt owner
Old Feb 1, 2013 | 04:22 PM
DanLb92's Avatar
Exclamation soon to be S70 Glt owner
im getting a 1998 S70 glt and wanted to know what turbo was on it and if you could take a turbo from a 850 turbo 16 or even 15, will it bolt on?
and would I have to touch the ecu at all if i put a 16t on it from a 850
anything would be nice, and what is the fuel rail pressure on it? would i neeed to upgrade that if i put a 850 turbo
Thx
Old Feb 1, 2013 | 05:46 PM
Yes the 16T will bolt on from what I've read. The turbo will not make the car faster if you don't upgrade the ECU. You can't just drop another ECU in there, it should be one from a T5 '98 S70 or one from a mod shop. It will be set to boost the larger turbo higher.
Fuel pressure should be fine unless you get a real high boosting ECU. In that case you may need to change the injectors to allow more fuel flow, not more fuel pressure.
Old Feb 2, 2013 | 01:14 AM
gdog's Avatar
Thx
If you want to do all that why not just buy a T5 (2.3L w/HPT) instead of the GLT (2.4L w/LPT)? The 2.3L is a more robust engine and more suitable for "tuning".
Don't get me wrong; I really enjoy our GLT but you need to be a little more careful about adding HP to it.
Old Feb 2, 2013 | 07:42 PM
DanLb92's Avatar
okay and the glt is being given to me lol could i take the turbo from a t5 and put it on the glt?
Giorgi.Varamishvili
Jun 24, 2016 11:45 PM
cganotisi
Jun 16, 2006 11:36 AM
cmd1978
Feb 5, 2006 07:25 PM
Vaccam
Jan 31, 2006 11:56 AM
lodgebros
Nov 20, 2005 04:58 PM
