Speed Sensor Fault
Old Aug 31, 2012 | 01:17 PM
miked213's Avatar
Default Speed Sensor Fault
I have a 2000 S70 and I have an error code #P0500, which is coming up as a "Vehicle Speed Sensor Fault." My "Check Engine" light has flashed a couple times, which I am now assuming this is the reason.
My air conditioner comes and goes as well. Seems to quit working when I am sitting in traffic or idling. I had it re-charged a few months ago, but figure I have a leak.
Anyone have any input?
Old Sep 7, 2012 | 12:02 AM
Lifesgoodhere's Avatar
could be any number of things with the a/c get some gauges hooked up on it and see what pressures it is running.
as to the Speed sensor. ABS, wiring, or the crank position sensor. Be a start.
Check engine light will flash is the computer has never displayed the code before. after that it will not. Only flashes for new codes. I would check the connector first, and make sure the loom isnt being pinched anywhere.
Old Nov 1, 2012 | 05:32 PM
patricka's Avatar
MAKE certain that,s what is,if indeed contact me I have at least 3 working ones,will sell u one for cheap.
v1lcins
May 20, 2022 10:53 AM
jonqu
Sep 4, 2013 12:45 PM
itr
Nov 22, 2010 07:05 PM
sdc2000
Jun 29, 2009 04:52 AM
parrym
Nov 7, 2004 11:30 AM
