Speemoter Sensor location
Old Feb 6, 2009 | 02:43 PM
garciarc's Avatar
Question Speedometer Sensor location
Our 98 S70 Speedometer is intermittent. We had the system flushed and filled, but it didn't help. I was told that I should remove and clean the Speemoter Sensor. But I have no idea where it is located. Help would be greatly appreciated.
Old Feb 6, 2009 | 04:51 PM
T3AMVOLVO720's Avatar
Default try this?
for my 1996 854T is located right behind the brake rotor
your going to have to take the wheel off and the only wires running to the back of the rotor is the speed sensor
other than that theres your brake lines
there are two of them
if not i would think the other place on volvo would deff be the transmission try it out
good luck.
Old Feb 6, 2009 | 06:57 PM
garciarc's Avatar
Default Speedometer Sensor location
I forgot to mention that, I pulled and cleaned all four of those speed sensors. They were pretty nasty. However the surfaces that the sensors (Rotors) were sensing, were pretty clean. Is there not a speedometer sensor that mounts to the trany?
Old Feb 7, 2009 | 10:03 AM
The ABS module controls the speedometer. The ABS module might be bad.
Old Feb 7, 2009 | 11:55 AM
would that be the same for a 850T?
i keep looking and only found two spots the tranny and the rotor area
checked em both and they clean
i just dropped a new motor in and it stopped working
it was working fine before the car was under construction for5 months and now the speedometer doesnt work still havent figured it out yet
Old Feb 7, 2009 | 12:18 PM
Yes it would be the same. Is the ABS light on?
Old Feb 7, 2009 | 08:14 PM
garciarc's Avatar
Hey tech, That's what I'm suspecting. Removing it and sending it off to be fixed wouldn't be a problem for me. And I've read through alot of the other Speedometer problem threads. Most of those threads also have ABS Light on, Up arrow flashing, & CEL codes. And in almost all those cases, the ABS module fixed the problems. Our car isn't experiencing any of those other problems, other than the intermittent Speedometer. Thoughts?
Old Feb 7, 2009 | 09:31 PM
Still possible the ABS module.
I have not seen anything else really that stops the speedo from working.
Old Feb 8, 2009 | 11:36 AM
garciarc's Avatar
Yesterday, I disconnected the ABS module, and plug it back in. Just to see if maybe there might be some corossion on the contacsts that might be creating poor contact. So far the Speedo is working. If it quits working again, I will go purchase some contact spray cleaner. And if it fails again, I will most defenitly remove the ABS module and send out for repair. At least now I see a silver lining on the horizon. Thanks for your help.
Old Feb 8, 2009 | 11:57 AM
Your welcome.
Old Feb 8, 2009 | 03:10 PM
Yes the abs light was on but i found the wires ive been looking for i had a shop do my second motor but they cut some wires so thats why im doing the third engine but i had another thread about the color of wires for the speed sensor and i finnally found them i had to go to a junk yard and follow the wires to the harnes
but im hopin that will shut the ABS and Tranny Flashing Light and make the speedometer work again i get my new head tomorrow from the shop so we will see shes got 0 miles
Old May 17, 2009 | 11:06 AM
jianiinc's Avatar
tech, garciarc, I have a 92 940turbo with a speedo and odometer that are out but the rest of the gauges work fine. Where is the ABS connection I want to see if possibly that is why my speedo isnt working.
Old May 18, 2009 | 09:10 PM
You sensor is in the rear Diff. cover.
Old May 24, 2009 | 06:36 AM
Volvo4Life70's Avatar
I have a 98 s70 glt, but my friend has a 96 850 that was having the same problem, so I removed the abs mudule and opened it(be carefuul when cutting open) I found that most of th pin solders to the bourd were cracked, so I soldered them. Now everything works and the abs light cleared on its owm as soon as you drive.
sabydady
Jul 7, 2009 04:58 PM
Qamar
Aug 6, 2005 12:07 PM
a2aa
Aug 3, 2005 11:50 PM
dave_n_s
Jan 29, 2005 01:18 AM
jdnas
Oct 5, 2004 10:40 PM
