Stalling with 97 850
Old Apr 27, 2011 | 06:34 AM
mattrn's Avatar
Default Stalling with 97 850
I'm new here. I have a 1997 850 that Stalls as if running out of gas when warm only. It usually will restart only to die out again. If I let it sit a few minutes, it will start, but needs the accelerator to be held down to go anywhere. I have replaced the fuel filter. Any suggestions?
Old Apr 27, 2011 | 09:26 AM
HeadDragon's Avatar
Get your codes out of the system. See what you get, MAF most likely. If you get ABS failure it can effect the Main puter as it is in front of the main puter on the CANBUS. My ABS puter works great when below 0. The computer when it kicks in and out will kick out my cruise control and make my car stutter when it does. I had a bad MAF and it did just what you said when it was warmer.
Don't buy cheap MAFS. Autozone and Checker MAFS will report failed most times even when new. They work alright but report errors. I got my last from eeuroparts.com for 150.00
volvoinct
Jun 8, 2022 03:30 PM
zldecker
Feb 19, 2006 11:25 AM
Riculus
Jan 20, 2006 01:30 PM
jfikentscher
Nov 11, 2005 02:13 PM
miami_twice
Dec 22, 2003 01:02 PM
