Thermostat
Old May 22, 2008 | 01:35 PM
chachouu's Avatar
Banned
Default Thermostat
I am replacing my thermostat soon,I was told I should flush the coolant as well.
what hose TO REMOVE in order to flush it completely
1998 S70 non turbo
Old May 22, 2008 | 01:49 PM
jsj_297's Avatar
Default RE: Thermostat
With the thermostat out, you can take off the lower hose, radiator side and flush it. Thats probably what I would do myself.
Old May 22, 2008 | 05:28 PM
Also there is a drain on the bottom of the radiator on the drivers side.
Old May 22, 2008 | 07:34 PM
chachouu's Avatar
Banned
Now I am confused,I see the one on the lower right radiator (driver side),but there,s no other ones besides the top one that I can see.
Old May 22, 2008 | 07:40 PM
Are you talking about the hose or the drain?
Old May 22, 2008 | 07:47 PM
chachouu's Avatar
Banned
I clearly see the Hose, that I have to unscrew and detach,but the drain I don,t see it how far is it from the hose
Old May 22, 2008 | 08:06 PM
It is in the bottom of the radiator. It should be a little nipple sticking out. You will need a 13MM socket to loosen it.
Old May 22, 2008 | 08:24 PM
chachouu's Avatar
Banned
Thanks TECH,I guess I will find it,but is really necesary to fully undrain it.
Old May 22, 2008 | 08:36 PM
If you are flushing it then I would say yes.
If you are just changing the thermostat I would say no. You can change the thermostat and not loose to much of it.
Old May 22, 2008 | 10:45 PM
jsj_297's Avatar
I agree with Tech, if youjust change thermostat, andthe coolantlooks good, I would let it eat.
Old May 23, 2008 | 07:18 AM
chachouu's Avatar
Banned
I only have water in there which is why I want to flush it and put a Gallon of 100 antifreeze and half water.
Old May 23, 2008 | 09:44 AM
jsj_297's Avatar
I hope you don't live in Alaska. lol Just kiddin Sounds like you have a plan.
Old May 24, 2008 | 06:50 AM
chachouu's Avatar
Banned
I doubt I could have survived winter time,lol
robert213
May 30, 2006 03:23 PM
cameron
Feb 8, 2006 06:06 AM
Eric
Jan 11, 2006 11:43 PM
Buck
Aug 23, 2005 09:20 AM
jcmartin
Mar 1, 2005 01:46 PM
