Timing belt tensioner question
Old Jul 10, 2024 | 09:39 PM
Psaboic's Avatar
Default Timing belt tensioner question
My 98 S70 GLT has the mechanical belt tensioner. My 98 S70 T5 has the hydraulic one. I prefer the hydraulic type tensioner over the mechanical type. When I change the timing belt on the GLT next week I'm wondering if it is possible to change the tensioner to a hydraulic one? If so has anyone ever done that? Again is this swap even possible?
Old Jul 11, 2024 | 05:45 PM
Psaboic's Avatar
I'm guessing by the crickets, either the answer is no or no one knows for sure .......
Old Jul 15, 2024 | 09:22 AM
Psaboic's Avatar
Ok then.....I'm going to try it and see. Worst case scenario is I have to buy another timing belt set with the mechanical tensioner, and keep the hydraulic set for the T5.
Old Jul 20, 2024 | 10:47 PM
Psaboic's Avatar
Ok, to close this out, yes you can put a hydraulic tensioner in a car that had a mechanical tensioner and vice-versa. As long as you get the correct belt (148 teeth for hydraulic tensioner and 142 teeth for a mechanical tensioner) it works fine. The tapped holes are already there. Did it today and it works fine.
Psaboic
Jul 2, 2024 09:32 PM
oragex
Feb 8, 2014 12:17 PM
Psaboic
Apr 4, 2013 04:12 AM
silverstreak98
Feb 24, 2011 10:58 AM
Lawbrum319
May 14, 2006 09:06 PM
