Trans issues
Old Apr 23, 2008 | 11:18 AM
BuildinAs70's Avatar
Default Trans issues
ok.. first issue in a while.. pulled up to the drive in at wendys put it in N got my stuff, back to D nothing there, dident shift or somthing, got out, pushed it, gave it some gas. felt like the trans lost pressure or the fluid is not good, slipped bad started to roll at about 4 grand then grabbed and felt normal, crawled home, by the time i got it home it wouldent go anywhere. had to turn car off then back on to get it to move, the up arrow for winter mode flashes now, i dont know what to to do, i have no idea and bad luck with trans's.
could it be electronic or the trans just go bad, there were no symptoms, its never slipped before or anything. just went all of a sudden.
any help would be great, ive had the car for less than 5 thousand miles....
Old Apr 23, 2008 | 11:47 AM
miller guy's Avatar
Default RE: Trans issues
how is the transmission fluid? any leaks under your car? it could deal with the filter for the transmission. if there is too much gunk caught up in it then your car will have trouble shifting gears. transmission repairs are very expensive. see if you can diagnose the problem yourself. check the fluid level and the filter. for a 98 i doubt the gears are worn down.
Old Apr 23, 2008 | 12:07 PM
fluid levels are fine, not a leak anywhere. yea i really have no idea, ill probly drain the old fluid and fill it back up with new stuff..
Old Apr 23, 2008 | 02:19 PM
miller guy's Avatar
are you positive it's your transmission. could be fuel pump. does your car hesitate?
Old Apr 23, 2008 | 03:33 PM
yea its the transmission, i give it gas and it will rev, it will red-line if i want it to. but it doesnt go anywhere. or it will creep forward very slowly with no torque.
Old Apr 23, 2008 | 06:35 PM
Maybe tranny gone.
Old Apr 25, 2008 | 09:14 AM
thats what im afraid of..
Old Apr 25, 2008 | 01:17 PM
Ahmed's Avatar
Take it to the volvo dealer and see what the say. If they say you need a new transmission then I would take it to a transmission shop like AMCO to see I much it would cost to repair because the dealer will only replace the trannny. I know the early S80's and the XC90's have tranny problems with there GM transmissons but I rarely here the S70 transmissions going bad. How many miles are on the car and do you know if the owner before you ever changed or flushed the transmission fluid.
Old Apr 25, 2008 | 01:40 PM
the car just turned 127k and the fluid is kinda dark and burnt.
im seeing in other forums this has happened and its only been a solenoid or little electric problems. anyone have an opinion on that?
cause if i turn the car off thenback on it will enguage then after about 50 yards it will dinenguage
Old Apr 25, 2008 | 02:41 PM
Ahmed's Avatar
If the transmission fluid is dark and burnt then I would get the fluid replaced or the tranny flushed at the volvo dealer and see what happens. And since the fluild is dark and burnt I dont think the owner before you ever replaced it.
Old Apr 25, 2008 | 07:08 PM
Get the fluid changed but in the end I will bet the tranny is going.
Maybe a tranny shop can track it down to a soleniod then go for it.
The Dealer usually won't mess with it.
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
