Vibration at stop lights while in gear
Old Jan 14, 2012 | 06:41 PM
  #21
cheesenacho's Avatar
I ordered, received and replaced both mounts on top, the one near the firewall and the other on top of the engine. Replacing those parts helped but did not completely resolve the issue, I plan on installing the transmission torque mount on the underside. The two top mounts were real bad so i'm thinking the bottom must be bad too, so for $50.00 why not.
Old Jan 14, 2012 | 07:36 PM
  #22
Today I replaced the 2 top engine bushings in an attempt to get rid of some unwanted vibration. The old bushings were trash, the new (blue from IPD) ones helped some. I'm hoping if I replace the underside transmission torque mount will help even more.
The vibration i'm trying to control is only present at at a stop light, once I give it gas it goes away. What else should I check? Ideas?
Old Jan 14, 2012 | 08:03 PM
  #23
JRL's Avatar
JRL
Don't you understand that the blue bushing is NOT what you want to do if you want it smooth?
You need to install VOLVO OEM mounts and rubber bushings, not urathane bushings,
THAT's what make these cars vibrate
Old Jan 14, 2012 | 11:49 PM
  #24
+1 with JRL. The blue IPD mount does cause idle vibration. Again, check the mount at the front of the motor behind the right front wheel.
Motor mount, right side, Volvo S70, replacement instructions
buckhr
Apr 24, 2013 05:03 AM
x-angel
Jan 18, 2013 09:41 AM
pnhons
Nov 20, 2011 05:26 PM
Word Maven
May 25, 2009 12:59 PM
ocean238
Apr 17, 2008 06:20 PM
