Vibrations at 65mph
Old Mar 11, 2008 | 08:35 PM
nathan's Avatar
Default Vibrations at 65mph
Hey all, have anissue with my 2000 s70 wondering if anyone has some input. At about 63-65mph the steering wheel starts to noticeably vibrate and shake. I thought it might be related to the transmission but there is no 'slipping' of the gears, thought it might be the alignment or balance but got that taken care of and the vibration is still there. Any thoughts?
Old Mar 11, 2008 | 11:10 PM
Volvo V70R's Avatar
Default RE: Vibrations at 65mph
Tie rods?
Old Mar 11, 2008 | 11:55 PM
01_fast_ride's Avatar
Atire could be 'out of round'. It would give the same sensation that an out of balance wheel gives and cant be fixed by simply balancing them. I'm not sure of any particular ways of spotting it other than possibly jacking up the car and rotating thewheel while looking (very closely) for any mis-shapened spots. That is my guess.
Old Mar 12, 2008 | 12:12 PM
samadkins29's Avatar
does it continue to shake or only from 63-65? If it continues check the engine mounts and upper engine stabilizer mount
Old Mar 12, 2008 | 04:25 PM
Eric J's Avatar
Those who did the alignment would have noticed bad tie rods, and should have seen an out of round tire. Does the vibration lessen while accellerating or steering one way or another?
Old May 30, 2008 | 05:01 PM
s70 2000's Avatar
Vibration disappears below 63. Tech drove it and couldn't find a problem. Just had a new upper motor mount and power steering line installed, didn't fix the vibration.
Does not have anything to do with turning, braking. just magically starts between 63-65 mph.
Old May 31, 2008 | 11:52 AM
jsj_297's Avatar
I had almost same problem, mine turned out to be the rim, pass side front was crapped out. Cheap ace volvo rim.
gbarney10
Apr 28, 2008 01:41 PM
S70ismyfriend
Mar 22, 2007 02:00 AM
flamejet
Sep 10, 2006 02:29 AM
Jutboy244
Apr 26, 2006 12:49 AM
BlackDiamondBound
Aug 4, 2005 01:28 AM
