Whistling noise....
Old Sep 5, 2007 | 02:52 PM
d2jreality's Avatar
Default Whistling noise....
Hey guys,
99 S70 T5, When I accelerate and let off right away, I get a whistling noise coming from either the exhaust or the engine.I can't figure it out. It only does it in drive not in park or nutruel. Any ideas?
Old Sep 5, 2007 | 05:53 PM
Default RE: Whistling noise....
That should be the bypass valve on the turbo releasing pressure which is normal.
Old Sep 5, 2007 | 06:00 PM
d2jreality's Avatar
I never heard that comeout of any other turbo cars. I could be the bearing inside the turbo. Its hard to get to where the bearing is to check it. Or like you said tech, if that is the case the valve is on its way out.
Old Sep 5, 2007 | 06:04 PM
No that is normal.
I am suprised you have never heard it before.
It is the factory setup like a blow off valve.
Old Sep 5, 2007 | 06:26 PM
d2jreality's Avatar
I believe you but it didnt start doing that until around 179,000 miles. I purchased it at 50,000. (?) It was quite up until that high of mileage.
Old Sep 5, 2007 | 06:38 PM
My R with 88,000 miles does it.
My turbo with 190,000 miles does it.
Maybe you also have a turbo hose going bad making the noise louder than it normally would be.
Old Sep 5, 2007 | 06:45 PM
d2jreality's Avatar
That may be the problem. Good suggestion. I'll check it out. Has your fuel pump gone out yet?
Old Sep 5, 2007 | 06:48 PM
I have only had the white turbo for about 6 or 7 months no problems with the fuel pump.
The yellow one only had about 2 months. Both pumps look like they have been there a while.
Old Sep 5, 2007 | 06:52 PM
d2jreality's Avatar
Mine went out as far as I know. Wont be sure until 2moro tho. Its coming in finally. I believe its the original. The car has 224,000 miles on it. Do you know where I can find a cam locking tool?
Old Sep 5, 2007 | 07:20 PM
Maybe e-bay.
The tool comapny's want way to much $$$$ for the Volvo tool.
Old Sep 7, 2007 | 05:29 PM
Auburn T5's Avatar
Check the intercooler hoses for cracks. If there's a crack or hole, the boost will whistle as it's forced out the small holes/cracks.
Also, at that mileage, I'm betting that the diaphram in your compressor's bypass valve is all but disentegrated. Buy a repair kit here.
http://quickbrickmotorsports.com/prod_cbvupgrade.html
SDozier
Mar 19, 2011 03:43 PM
coolsingh
May 23, 2008 08:17 PM
datastreamcom
Aug 20, 2007 11:23 PM
volvo94404
May 25, 2007 06:49 AM
danielribo
Oct 23, 2005 06:38 AM
