why will 1998 v70 only start on the second attempt?
Old Jul 11, 2012 | 07:53 PM
carter_allen_'s Avatar
Default why will 1998 v70 only start on the second attempt?
My '98 v70 is coming up in 190k miles and it just started having ignition problems. When the problems started, it would only be on extremely hot days when the car sat for > 8 hours in the heat. I would go to start the car and on the first try, it would turn over for awhile but no start, so i would take out the key and on the second attempt it started completely normally. However, the problem has progressed to where on even mild temperature days, and letting it sit for over only 3 hours, i will go to start it the first time and it will turn over for awhile but no start. The difference is now (aside from the temperature and time changes) that the second time i go to start it it will eventually start but as soon as it does it immediately sounds like it's going to sputter out and the rpms plunge close to 0 until half a second or two later the rpms will shoot up higher that usual and then settle back down to normal (i never apply pressure to the gas pedal). Once started, the car runs fine and there has been no loss in power, acceleration, ect... My local mechanic says it's just an age problem (i've driven cars with 300k miles that dont have any trouble like this) but i want to know what the problem actually is... Any suggestions?
Old Jul 11, 2012 | 08:15 PM
Low fuel pressure?
Old Jul 11, 2012 | 08:34 PM
gdog's Avatar
Without more diagnostic work this is just a guess but I would ck the fuel pump relay first.
carter_allen_
1998-2000 model year V70
Jul 11, 2012 08:14 PM
VolvoCanBec
May 12, 2012 12:30 AM
jbachus
Dec 20, 2011 11:43 PM
ekanenh
Jul 20, 2011 05:34 PM
SpecialT
Nov 8, 2007 12:36 PM
