Windows Fuse
Old Aug 7, 2010 | 12:58 PM
desolator's Avatar
Default Windows Fuse
Hi
Where can i find the windows fuse or relay with the metal box for the windows , i searched but i couldn't find one what should i do about it, should i just connect a wire or is there is another solution.
thank you
Old Aug 7, 2010 | 05:31 PM
What is the problem? How do you know the fuse or relay is bad?
Old Aug 7, 2010 | 06:40 PM
desolator's Avatar
well when i bought this car the windows and slideroof was not working.
anyway i check the fuses and didn't see anyone for the windows until i did read the owner service manual i saw the windows fuses located under the plastic cover in the corner so i checked and saw the base melted and when i removed the fuse it was like melted and lots of peaces so i changed it with the one in the top of it ,it look the same and now the windows and slide-roof are working but now i have missing fuse.
mjohnny
Mar 18, 2013 02:35 PM
mischief4l
Sep 2, 2008 07:13 PM
rtarabou
Dec 6, 2005 09:08 PM
becbam
Aug 30, 2005 02:28 AM
punxworm
Jun 25, 2005 04:10 AM
