@$%&^$#* Fuel Door
Old Oct 19, 2010 | 02:28 PM
donf's Avatar
Default @$%&^$#* Fuel Door
May sound like a minor annoyance but after 5 years of this I'm fed up!
After refueling, the fuel door will swing out away from the body side latch before I build up enough speed for the lock to activate. Then it locks and the door is swinging in the breeze and won't close until you unlock it again.
Usually takes 2 or 3 attempts to get it closed properly. The old S70 works flawlessly, as do my other cars so it IS possible! I asked the dealer once - "It's working just the way it was designed", sigh.
Any ideas/fixes??
Thanks
Old Oct 21, 2010 | 12:04 PM
Ciesco's Avatar
Default fule door...
the spring is replaceable if you want to spend a couple bucks to do it...you simply punch out the old one's pins and hammer in the new ones...very easy job...
Old Oct 21, 2010 | 01:01 PM
75ohm's Avatar
More like gently tap in the new ones while praying you don't break one...
Old Oct 21, 2010 | 03:30 PM
donf's Avatar
Spring?
Spring?
Spring?
Well, it's done it since new and I always thought a spring would be a good idea. Must be have been "Made in Detroit" .
Old Oct 22, 2010 | 01:06 AM
re100005's Avatar
I've had a 2000 S80 since 2004. It's not the spring, but the couple little hooks on the fuel door hinge that have snapped off. It's happened to me twice now. The spring is still attached but the hooks where the spring rests on have snapped. It's an easy replacement, use a roll pin punch to knock the pins through and the new pins are attached to the new hinge. Gently tap the new pins into place and the new hinge will be friction fitted.
Part number 31265160 (replaces 30649879).
The part isn't that expensive, so since the second time it broke. I keep an extra one in the garage.
qcvol
Jun 17, 2013 09:55 PM
garydrenk
Sep 18, 2010 12:02 PM
huzzsaba
Apr 2, 2009 05:35 PM
the_happy_driver
Jun 26, 2008 12:47 AM
andrewlittell
Dec 10, 2007 07:39 PM
