01 S80 a/c service mechanic said compressor cycling normal??
Old Jun 29, 2014 | 12:50 PM
midimykeys's Avatar
Question 01 S80 a/c service mechanic said compressor cycling normal??
Hey everyone ~
I took my S80 2.9 to get an a/c service. Previously I had tried to add/take out R134 to make the air in the cabin cooler. Only being able to add on the low side, I was certain I could not get an accurate amount in the system. After a few days with experimenting with R134 amounts, the compressor clutch started to engage and disengage every 15 seconds after the car a/c had been on for about 5 minutes (when the pressure had built up maybe). When disengaged, the air is cold, but it rises by about 5 degrees with a little humidity until it kicks in again. I gave up, so I took it to a local mechanic who evacuated the system, air, and oil. He said there was 2.8lbs of refrigerant in the system, and it should only have 2.17lbs. I was starting to freak out until he told me that I couldn't overfill the system because of high and low pressure sensors that were a part of the system. He refilled everything, and I drove away with pretty cold a/c. However, the compressor still cycles on and off every 15 seconds. I took it back, and he said that it should work itself out in a day or two, when the computer is used to the amounts of refrigerant. This seemed unlikely to me. Is there something else it could be? Did I ruin something overcharging it. It's bearable in the 95 degree heat, but I don't want the compressor or clutch to wear out because of incessant cycling.
Volvo for life so far
Old Jun 30, 2014 | 01:17 PM
midimykeys's Avatar
54 people have viewed this, and nobody is a pro?
Old Jul 1, 2014 | 10:12 AM
theboneskes's Avatar
He is right... the compressor is doing its job correctly!
The only time a compressor should ever be overfilled is when the rings are wearing out in it and you want the cooling. It raises head pressure a little but usually works. Yes, I am HVAC certified!
Old Jul 5, 2014 | 04:09 PM
Disco2's Avatar
The compressor will disengage when the evaporator temp drops to 6C (about 42F) How's your cabin filter? dirty filter -> reduced airflow -> compressor cycles so the evaporator doesn't become a block of ice.
sghokie
Jul 25, 2011 05:00 AM
Systek
Apr 13, 2008 01:05 PM
Pretorien
Oct 12, 2007 10:58 PM
Nand12
Jun 1, 2006 09:08 PM
