04 S80 t6 ABS module
Old Apr 25, 2012 | 04:32 PM
VenturaS80's Avatar
Default 04 S80 t6 ABS module
I've been lurking on here for a week or so looking for an answer. I have a 2004 S80 t6 that is throwing the "brake failure stop safely" and ABS warnings. It's nothing in the wheels or sensors as they were just checked. The mechanic said it was the ABS module.
Three questions:
1. Can this year module be rebuilt? If so by who?
2. Where is the module located and how do I get to it?
3. Can I drive the car with the ABS module out?
Thanks in advance for your anticipated help.
Ventura S80
Old Jul 3, 2012 | 03:41 PM
Pos392@yahoo.com's Avatar
I have the same issue, and from reading these threads I have found this website recommended by a few people. I called them today and they seem to know what is up.
Products for Volvo - Xemodex Inc. | Xemodex Inc.
Old Oct 15, 2012 | 04:18 PM
pneborg's Avatar
Smile xemodex abs module repair for S80 work great!
I used xemodex 3 weeks ago to repair my S80 ABS module. It was relatively easy to remove the module. Sent it to xemodex via their preprinted mailing label. Drove around for a week without the module. It came back within a week. I reinstalled it (note you have to open the wiring harness's connector then insert the wiring harness into the module and then close the connector plastic tab to lock the wiring harness back into the module snugly. I fussed a little with the harness before realizing it needed to be opened first and then insert the wiring harness and then close) and it works great. no more brake failure warnings. Everything works fine including cruise control.
tahafisaka6
Nov 12, 2012 02:28 AM
DT333
Jun 2, 2011 04:29 PM
tahafisaka6
Jun 1, 2011 11:32 AM
cswadner
Oct 11, 2009 08:08 PM
E99S80T6
Sep 9, 2008 07:13 PM
