1999 80T6 Struts
Old Nov 10, 2006 | 08:53 PM
ramp's Avatar
Default 1999 80T6 Struts
I need to replace front struts; the front left is leaking fluid. Any recommendations for type and where to buy?
Thanks
Old Nov 11, 2006 | 09:15 AM
ramp's Avatar
Default RE: 1999 80T6 Struts
Follow up to last post. The lower ball joint rubber boot is torn. With 130,000 miles should I just rebuild the whole front end if I am going in here? Also the viscous coupler is leaking, pretty good, Comments please.
Old Nov 11, 2006 | 02:26 PM
If you can afford it replace both lower control arms if the bushings are bad.The struts,Don't forget the spring seats to,
Sway bar links, Balljoints.
Not sure about the viscous coupler.
Old Nov 12, 2006 | 11:57 PM
ramp's Avatar
Anyone offer suggestion on type of strut? Koni, KYB, Blis..
Old Nov 13, 2006 | 12:16 AM
From what I have heard and seen the Bilsteen are the best.
Old Nov 13, 2006 | 05:21 AM
studd34000's Avatar
yeah i have blisteen and they are great
Old Nov 13, 2006 | 05:15 PM
ramp's Avatar
Tranny fluid from viscous coupler. I just need to replace the mechanical seal on the drive shaft.
Struts, Have looked into in, why are KYB soo cheap? Are they any good or just stay with the proven Bilsteins?
Thanks
Old Nov 14, 2006 | 08:49 PM
KYB is usually a rougher ride from what I hear good for Solid lowered cars.
Old Nov 15, 2006 | 03:08 AM
poopbunny's Avatar
My last struts were KYB, they felt a little too stiff IMHO.
mrybar
Apr 9, 2019 09:19 AM
Porschenut
Apr 30, 2014 09:20 AM
Matt Lagusis
Mar 7, 2012 07:15 AM
hughrhodes
Dec 4, 2011 06:27 PM
ADB
Jul 22, 2011 09:22 PM
