1999 s 80T6 Lack of top end power
Old Jul 17, 2011 | 09:09 PM
ADB's Avatar
ADB
Default 1999 s 80T6 Lack of top end power
Hi, 1999 volvo s80 t6 154k miles, Engine idles smooth, but it has a slight shutter when I accelerate hard and does not have follow through power when I floor the gas pedal, low end power seems fine, just when I floor the car around _+4000 rpm when the thin turbo is supposed to kick in the power curve flattens.
Any Ideas?
Thanks
Old Jul 19, 2011 | 07:36 AM
When you floor it the turbo kicks in long before 4000 rpms. Should kick in around 2000 rpms. It sounds like you may have exhaust restriction or maybe a bad catty. You could also have a turbo going out.
Do you have any codes stored in the computer?
Old Jul 20, 2011 | 08:16 AM
ADB's Avatar
ADB
I have code P0303, I am going to change the plugs and #3 coil. I'll post my results.
Thanks
Old Jul 20, 2011 | 08:52 AM
You could swap the coil with another position to trouble shoot it. If that doesn't work and you need to change a plug, replace all of them with OEM plugs. Especially if they have not been done in the past 30,000 miles.
Old Jul 22, 2011 | 08:26 PM
ADB's Avatar
ADB
I changed all the plugs with Bosch platinum and replaced the coil just in case. Car runs great now. Next I have to deal with the oil separator box ( it is blowing oil from the dip stick tube when I drive it hard), wish me luck.
Old Jul 22, 2011 | 09:16 PM
You'll get it worked out. As for plugs, you may want to try OEM plugs next time.
Old Jul 22, 2011 | 09:22 PM
ADB's Avatar
ADB
Thanks
mrybar
Apr 9, 2019 09:19 AM
ramp
Nov 15, 2006 03:08 AM
moburki
Dec 23, 2004 04:44 PM
