1999 S80 No Throttle Response
Old Sep 10, 2014 | 08:48 AM
mohmdomar's Avatar
Default 1999 S80 No Throttle Response
Hello
I am experiencing a very annoying problem with my 1999 6 cylinder non turbo S80, most of the time the throttle has no response whenever i press on the accelerator and other times it works just fine but with slow throttle response i put it on vida dice diagnostic cable and this is what i found:
https://imageshack.com/i/expYUdPkp
https://imageshack.com/i/iprABUHip
i have had the following done with no use:
changed thee alternator
changed the throttle
changed the tps on the throttle with contactless one
changed the accelerator pedal
the car seems to work for couple of days whenever i disconnected the battery for five mins but then the problem comes back again and also I noticed that the accelerator has no effect (no throttle response) when pressed at the same time when pressing the brake pedal , not sure if thats normal
Old Sep 10, 2014 | 02:54 PM
Nickstone's Avatar
Originally Posted by mohmdomar
Hello
Definitely your the ETM (throttle body) ... Have it cleaned if you know someone, a lot cheaper than getting a new one installed. 99% positive this will fix the throttle response
pnpdiode
Aug 8, 2015 11:03 AM
RJSV70
2001-2013 model year V70
Nov 24, 2012 07:04 AM
catonakeyboardinspace
Jun 14, 2010 08:36 PM
robv70
Jul 5, 2008 06:44 AM
740_in_TX
May 25, 2006 08:54 PM
