1999 S80 T6 No Crank
Old Sep 14, 2014 | 09:50 AM
  #21
ES6T's Avatar
How are you checking continuity?
Old Sep 15, 2014 | 04:50 PM
  #22
rnmikes's Avatar
Ok. I was wrong. This time I used a multimeter to test continuity. There is continuity from 50 to 86. PASS sorry for the confusion. The original test was wrong.
Old Sep 15, 2014 | 05:13 PM
  #23
ES6T's Avatar
If there is power at 50 during cranking and not at 86, then there can't be continuity.
Old Sep 15, 2014 | 06:54 PM
  #24
rnmikes's Avatar
Default Grrr - So sorry.........
I went thru and checked over again. Something went wrong...here it is...
At starter relay:
87 - Continuity PASS
85 - Ground when cranking PASS
30 - Power at all times PASS
86 - Power when ignition in start position PASS
ALL FUSES have been checked - PASS
The first time I tested this, I didn't do it right. There is power all the way through the really from the ignition switch. But what I want to make sure of is 87...continuity to what?
SOOOOO SORRY.
Old Sep 15, 2014 | 06:59 PM
  #25
ES6T's Avatar
Continuity between 87 and the starter solenoid (green and red wire). How are you saying continuity there is good when you don't know what you're measuring? Giving made up results is not going to help.
Old Sep 15, 2014 | 07:05 PM
  #26
rnmikes's Avatar
Not made up results. So sorry. It was my mistake. I am now using a multimeter set to the right option for all tests. I'm sorry. I don't know what happened on the first time thru. And I did check continuity just now from 87 to starter with the right setting on the meter. And there was zero resistance. Please accept my apologies.
Old Sep 15, 2014 | 07:11 PM
  #27
ES6T's Avatar
Is there power at 87?
Old Sep 15, 2014 | 08:57 PM
  #28
rnmikes's Avatar
All right. Obviously, I am a moron. Here's what's REALLY happening at the relay. Had a friend verify with me. Taught me something about it all...here goes...
87 to solenoid. Continuity PASS
86 to 50 ignition switch in position III: Continuity and provides power to 86 PASS
30 has power, but 0.76 volts. very little. PASS?
85 to ground continuity when ignition switch in position III. FAIL. Did I get this right by checking for continuity at cranking position?
87 no power at ignition switch position III. (and this, I think is expected if 85 fails, right?)
If you still have any compassion after this, please advise. Thank you for your time. YOU'VE BEEN REAL REAL GOOD THROUGH THIS WHOLE THING.
Old Sep 15, 2014 | 09:21 PM
  #29
ES6T's Avatar
By power, I mean battery voltage. .76 volts is not what you're looking for at 30. So you have no power to the relay.
85 should be grounded by the CEM during cranking.
87 won't have power because the relay does not have power or ground.
You said you checked fuses, but I would double check fuse 13 under the hood. That is what supplies power to 30 on the relay.
Old Sep 15, 2014 | 09:53 PM
  #30
rnmikes's Avatar
30 Now has power at 11.67 volts. Fuse 13 was not seated properly. The fuse passes inspection and test.
Old Sep 15, 2014 | 09:58 PM
  #31
ES6T's Avatar
So still no power to 87 when cranking? And no ground to the relay?
Old Sep 15, 2014 | 10:03 PM
  #32
rnmikes's Avatar
Correct. No power to 87 and No ground to relay.
Old Sep 15, 2014 | 10:25 PM
  #33
ES6T's Avatar
Gonna need VIDA to see why the CEM isn't grounding the relay.
No immobilizer message such as "start prevented"?
Old Sep 15, 2014 | 10:41 PM
  #34
rnmikes's Avatar
No immibilizer msg. Or start prevented. Ok. I'll update you later. Thx.
Old Jul 13, 2020 | 03:10 PM
  #35
TKat72's Avatar
Default Starter not engaging
Hi I was reading up 9n this issue and following your procedure and it appears I have no ground at 85. I assume I'll trace that wire to origin and clean or repair to solve ground issue? Thank you.
Originally Posted by ES6T
Yes, the green and red wire.
Is there power to pin 30 of the relay at all times? Is there power to pin 86 of the relay when trying to crank? Is there ground at pin 85 of the relay when trying to crank?
ZaphodBblbrux
Jul 2, 2012 09:54 PM
Lavid2002
May 26, 2011 06:00 AM
Lavid2002
Mar 1, 2011 06:20 PM
datderboy216
May 22, 2010 06:38 PM
rpsail7cs
Sep 25, 2009 09:12 AM
