2002 S80 Climate Control Module problem
Old May 21, 2015 | 10:54 AM
EChem's Avatar
Default 2002 S80 Climate Control Module problem
My CCM stopped working. I tried the reset by jumping battery cables, turning key to different ignition positions, in researching I found many different procedures to try any reset the CCM, none of which seemed to work. From reading other posts, it seems like I can not just get a used CCM and install as the software also needs to be re-installed to mate it to the car. My questions are:
If I get VIDA and Dice, would I be able perform this? I have been thinking of getting VIDA and have been going cross eyed trying to determine which version of VIDA to buy, and where to buy a reliable copy from, so any comments as to that would be appreciated.
Has anyone ever used a company to repair the CCM? I contacted AES and MASrepair, but neither do.
Thanks,
EChem
Old Oct 3, 2017 | 09:02 PM
Steve Martin's Avatar
Thanks,
EChem
did you get it working I'm having the same issue
Old Oct 4, 2017 | 02:57 AM
EChem's Avatar
Yes Steve. I purchased one off of EBay for $75. Knew it was from a near production run car as mine as mine was an anniversary edition. Had a plaque on the ECM as being "XXX of 500". Plugged right in and everything worked and it still is over a year later.
RoyCross
Mar 4, 2025 02:08 PM
mcslexus
Oct 31, 2011 08:59 PM
Rosew6211
Jan 24, 2009 07:22 PM
thejobark
Jan 30, 2007 01:30 PM
kenvolvos40
Jun 10, 2006 07:08 PM
