2001 s80 T6
Do you know anything at all about cars?
If so you should be able to handle it.
https://volvoforums.com/m_36636/tm.htm
That should give you a good idea.
Should be exactly the same as yours maybe 1 or 2 things a little different.
I was told that I would have to take the car to the dealer becaause of the ABS ands the computer would need to reset the ABS module. Tthis did not make sense to me. Also the s80 T6 has STC so I need the booster that has DSTC correct?
I bet you to take the car to the dealer. But if in case you'll decided to do it by yourself, first make sure that you are removing the four nuts that secure the booster. When you are sure you have the brake booster completely free, go ahead and yank on it from the other side of the firewall. If it doesn't come out easily, you've removed one of the wrong nuts.
______________________________
Autopartswarehouse Car Solutions.
Subvol
Dec 11, 2011 06:56 PM
schott1984
Sep 24, 2010 09:15 PM
