2001 S80 temperature issue
Old Sep 29, 2008 | 11:58 AM
jsfeni's Avatar
Default 2001 S80 temperature issue
Got in car this weekend, 90+ degrees outside. Outside temp read 34 degrees. I noticed it after the air was not blowing out the vents as it should. I could hear the blower but most seemed to come out of the dash vents.
Manual modes did not seem to help much. The air coming out was not very cold either. After about 10 minutes, it was cold. We stopped for a little while. When we started the car again, the temp read normal and the A/C performed as expected.
Today I get in and it is back to reading 34 degrees. Could the outside temp sensor be causing all of this? I don't care if it is accurate or not, but if it is messing up the A/C, that is different.
Any help or suggestions is appreciated.
Old Sep 30, 2008 | 05:59 PM
Default RE: 2001 S80 temperature issue
I believe it will affect the A/C.
Old Sep 30, 2008 | 06:08 PM
vegasjetskier's Avatar
ORIGINAL: jsfeni
If you push the 'recirc' button until the 'manual' light is lit does it blow colder?
Parasail Hilton Head
Penta
Oct 1, 2013 12:34 AM
Tex75
Nov 3, 2011 11:56 PM
wifescarslave
Feb 1, 2011 08:32 PM
frnorke
Aug 3, 2010 01:59 AM
alexr2130
Aug 7, 2006 02:22 AM
