2008 S80 Noise from engine compartment
Old Apr 27, 2017 | 11:02 AM
rickyc's Avatar
Default 2008 S80 Noise from engine compartment-broken mount?
I have a 2008 S80 with 3.2L engine. Engine has knocking noise coming from left side when going over bumps. Also can be heard immediately as engine throttled up or down when driven. I suspect it is left motor mount but I can not find its location. Please, can someone tell me where it is located and how i might get to it to replace it.
Thahks
Old Apr 27, 2017 | 11:16 AM
Smith Volvo's Avatar
Banned
Thahks
The torque mount #31430441 is quite common to go bad ...
Engine mountings. Fits: Volvo | Volvo Wholesale Parts Direct
Old Apr 27, 2017 | 11:24 AM
rickyc's Avatar
I've inspected that mount and can't find anything broken. Noise is pretty obvious that it is coming from driver's side.
Old Apr 27, 2017 | 11:29 AM
rickyc's Avatar
I've inspected the right mount and don't see anything that is cracked or broken. Noise is coming from drivers side of motor which makes me think it could be left mount. Do you know where it is located and how to access it?
Old Apr 27, 2017 | 05:02 PM
rickyc's Avatar
The torque mount looks okay, no signs of breakage. Still looking for location of left mount?
Old Apr 27, 2017 | 05:14 PM
ES6T's Avatar
Number 8 in the diagram is very common. Number 12 is the mount on the driver's side, located under the battery.
I've replaced several passenger side mounts and seen other guys do quite a few as well. Never had a driver's side fail yet.
Old Apr 27, 2017 | 06:17 PM
rickyc's Avatar
Thank you, how do you check to see if Mount #8 is bad?
Old Apr 27, 2017 | 08:30 PM
ES6T's Avatar
There should be a gap between the bracket the mount connects to and the mount. If the gap is too small, or none at all, then the bracket sits on the mount.
Old Dec 17, 2024 | 11:22 AM
calalb's Avatar
Default Replacing Right Mount and torque rod
Had similar issue with my 2008 xc70 80k miles.started when car was cold and putting in reverse I would hear a grinding noise. In 2-3 weeks it also started to make same noise in low gears for about 5-6 miles until the engine would fully warm up (my guess is the rubber on the mount and torque rod would expand from the heat enough to dampen the engine vibrations). Replaced the right mount and the torque rod and runs just like new. There are a couple of videos on youtube from volvosweden on how to replace those.
k4mdh
Sep 15, 2008 05:21 PM
NetAvatar
Feb 28, 2008 05:43 PM
Capo Cam
Feb 23, 2008 10:19 PM
robretpd
Jan 26, 2008 02:11 PM
VW
Nov 30, 2006 05:11 PM
