99 S80 Ticking Noise and PSF
Old Mar 25, 2019 | 07:29 AM
Graciesnycmama's Avatar
Default 99 S80 Ticking Noise and PSF
My apologies if this is redundant, but I've been unable to find the answers. I have a 99 S80 with 67k miles. About 3 months ago, my engine started making a ticking noise. It occurs when the car is in park or idling. It's not constant. I've had an oil change with full synthetic, and there isn't any leakage.
Also, since November 2018 I've gone through 1 1/2 cans of Pentosin CHF 11S power steering fluid. This seems like a lot to me.
Any advice and words of wisdom would be greatly appreciated. Thank you.
Old Mar 25, 2019 | 08:38 AM
The ticking noise sounds typical of a stuck lifter. You can try an oil treatment like Seafoam to see if that cleans it out. Any other symptoms like an occasional low oil pressure light at idle? If so you may need to drop the oil pan to inspect the pickup and possibly refresh the pump seals.
As to the power steering fluid - you shouldn't need to add ANY fluid so there's a leak somewhere. You'll need to go under the car and remove the shroud to look to see if its hoses or the steering rack seals.
Old Mar 25, 2019 | 09:05 AM
Thank you so much for your advice!
Ahmed
Dec 26, 2013 11:30 AM
merlinx
Dec 22, 2009 12:52 AM
karl53201
Feb 28, 2009 08:07 AM
daver80
Feb 24, 2007 01:00 PM
ghqasem
Sep 28, 2005 08:37 PM
