ABS Module replaced, now what?
Old Mar 26, 2008 | 09:12 PM
s80brady's Avatar
Default ABS Module replaced, now what?
I have a 2001 S80 2.9 with ~60K miles. I have been getting the message "Engine System Service Required" along with the cruise control working intermitently and the transmission having difficulty finding the correct gear between 50 and 55 mph. The message would be on for a few days then off for a few days. I took the car to a local and reputable Specialty Volvo Service Garage. No error codes could be found. They suggested replacing the ABS module. I bought a rebuilt module from BBA and had it installed.
No change in the symptoms or the message coming on and off.
Any suggestions????
Thanks
Old Mar 27, 2008 | 06:29 PM
Default RE: ABS Module replaced, now what?
There should be codes are they using a generic scanner to read it?
If so it most likely wont read the codes you will need a proper scanner to read them.
spankey
Aug 21, 2013 01:50 AM
EATMAN
Jan 29, 2009 12:50 PM
EATMAN
Jan 4, 2009 10:54 AM
CarFreak
Sep 9, 2006 11:39 AM
kaltek
Jun 12, 2006 10:42 AM
