AC low pressure side
Old Aug 14, 2012 | 04:19 PM
vrhs2011's Avatar
Default AC low pressure side
So, I need to recharge my AC, its starting to get cool; and I really don't feel like paying $268 at the dealer. Anyway, after doing some research, It seems like the low pressure port is under/near the coolant and power-steering tanks. that cap is marked by a '6nm MAX'. Is this correct? Thanks.
1999 S80 T6
Old Aug 14, 2012 | 05:04 PM
quietlymknnoise's Avatar
Yes just did mine.
Old Aug 14, 2012 | 05:50 PM
akabond's Avatar
wait..so what did you do . And what you mean by recharge the A/C
Old Aug 14, 2012 | 10:21 PM
vrhs2011's Avatar
@ Quietlymknnoise - How did you get the cap off??., it seems kinda tight in space wise
@ akabond- Well top it off with R134-a.
Well I couldn't do it today, too hot, and the engine needs too cool down.... Which can take awhile.
Old Aug 15, 2012 | 04:59 PM
I used a 19mm socket to loosen cap then attached a PRO AC recharge hose to it. I set air temp gauge, read pressure, then pulled trigger and away she charged up. Stopped at 37 psi with air temp of 85 degrees which a little low for air temp.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
brettboze
Mar 26, 2012 06:25 PM
pturner
Jun 25, 2010 11:29 AM
STREETFIGHTER50
Mar 12, 2009 07:29 PM
elderzap
Nov 7, 2007 04:58 PM
