Brakes fail when backing up S80
Old Jul 7, 2015 | 08:33 PM
MM1973's Avatar
Default Brakes fail when backing up S80
2006 S80 just had the brakes and rotors done. A few times (not all of the time) when backing out of my driveway I have experienced no brakes, until I pump them a bit. Brakes are fine when driving, problem did not exist before the brakes where done. Has only happened when reversing after the car has sat overnight.
Thoughts?
Old Jul 11, 2015 | 09:28 AM
majorcode's Avatar
Though I may suggest solutions, but its a brake job so better either you got to go back to the same mechanic who did the job or find a new one.
Don't drive the car until it fixed.
Old Jul 13, 2015 | 09:54 AM
could be the vacuum pump/ switch. Some Volvo models have a vacuum pump which builds up brake booster vacuum quickly on a cold start and runs until engine vacuum builds and takes over. Had to fix this on my S40 - it would take a firm foot to brake while backing but all was normal by the time I got to the bottom of my driveway (100ft or so). Do you hear a whirr noise cycle off/on when idling when you start up?
trauchut
Aug 27, 2009 08:06 AM
ithacaxc70
Mar 7, 2008 09:20 PM
Psaboic
Mar 11, 2007 01:59 PM
pisque
Sep 19, 2006 08:56 PM
elbert
Apr 12, 2006 10:04 PM
