A/C stops working
Old Sep 21, 2008 | 09:03 PM
jbss80volvo's Avatar
Default A/C stops working
My 99 S80's a/c will stop working all of sudden when sitting in traffic for a while, usually 15 minutes or longer. After the car sits a while it will start working again, cold as ever. Could this be a relay getting stuck? When it does stop working I don't here the compressor kick on or off.
Old Sep 21, 2008 | 09:06 PM
diehardgator1's Avatar
Default RE: A/C stops working
Mine was doing the same thing Get your ac clutch checked to see if it needs shimming Had mine shimmed week a go and no problems since. I used the plastic bread tags on mine will save you 150.00 to 200.00
Old Sep 21, 2008 | 09:24 PM
How can you tell if the A/C clutch needs shimming?
Old Sep 22, 2008 | 11:41 AM
Mine would cool a while then start blowing hot air Could turn the ac off few minutes and it would blow cold again. Then repeat the cycle. An independent mech took a broom stick and pushed the clutch in while blowing hot air and it started working he knew it had to be shimmed. If you try this be very careful as it is very dangerous to do I am talking about the broom stick part. If this is your problem go back a few pages and you will see how to shim with plastic bread tags. Did mine about a week and a half ago works fine. Will save you a couple hundred bucks over pulling the clutch off. Takes about 15 minutes is all 3 plastic clips and a tube of super glue
Old Sep 22, 2008 | 06:40 PM
Thanks diehard, now I hope I can get it to do it. You know how these intermittent problems are!
Old Apr 18, 2009 | 05:42 PM
JvO's Avatar
JvO
You are a genius...just did the fix using the bread ties and the ac works fine. It was very easy after I figured out how to access the clutch. Thanks.
Old Jul 9, 2010 | 12:16 PM
jorge02130's Avatar
can yall give me explanation in how to shim the a/c clutch on my volvo s80 2000. because i need to do it but dont feel like waisting 200 or 300 dollars. thanks
Old Jul 11, 2010 | 08:52 PM
get 3 of the plastic bread clips on bread only found them on hamburger buns here raise car easier to do from under car. put super glue on one clip at the time. Push ac clutch in with long screw driver insert one at the time takes 3 of them. let car sit for couple hours if possible so glue drys good My first job lasted 1 1/2 yrs just redid 2 weeks ago and working fine again
Old Jul 12, 2010 | 06:07 AM
jorge02130's Avatar
Ok, but should I put this where the a/c cluch are located? Or should I put them in the outside part where the first screw is located?
Daddy Z
Nov 10, 2010 05:50 PM
myteendriver
Jul 10, 2010 12:45 PM
acorales
Mar 26, 2008 09:46 AM
axis72
Jan 21, 2008 08:45 AM
autobeef
Oct 17, 2007 12:00 PM
