Climate Control Fuse
Old Jul 13, 2021 | 09:16 AM
Ron C's Avatar
Default Climate Control Fuse
So after getting caught in a torrential downpour, my climate control fan stopped working (won't come on for heat or AC) but green light on center control panel for climate control comes on. Sure sounds like fan motor fuse, right? Owners manual says climate control fan fuse is #11, 40 amp, lower engine compartment fuse box. I get there and.... no fuse in the socket. So, owners manual is wrong. Any help? 2009 volvo s80 Turbo.
Old Jul 13, 2021 | 09:36 AM
Originally Posted by Ron C
Sure sounds like fan motor fuse, right? control fan fuse is #11, 40 amp, lower engine compartment fuse box. 2009 volvo s80 Turbo.
On the diagram 6/28 is the fan, 4/31 is the fan controller powered by fuse 11 in the b fusebox. Vida or a compatible scan tool should be used first before randomly replacing parts - I've replaced a few fan controllers on that style climate system - they are not easy to get to.
Old Jul 27, 2021 | 01:28 PM
Ron C's Avatar
They (Volvi) actually moved that fuse. Its now below the entire engine compartment fuse box. And it was good. Motor itself was bad. Replaced. Warning, a special volvo tool is needed to replace that fan motor.
Old Feb 21, 2024 | 09:09 AM
Chris98765's Avatar
Has anyone the location that fuse #11 has moved to. I'm having the same issue with fans not switching off even when the car is switched off. Location 11 which should have a 40 amp fuse is empty. Volvo XC60 2015
Missy1001
Jan 31, 2025 01:00 AM
newengland
Oct 14, 2017 08:11 PM
DB1000
Feb 3, 2014 10:54 AM
ajaybali1
Jan 31, 2011 05:49 AM
NJBV70XC
Jul 11, 2010 07:29 PM
