Climate Control Problem Please Help!
Old Jan 11, 2007 | 02:27 AM
bluemotev's Avatar
Default Climate Control Problem Please Help!
I recently installed an AUX input converter on my S80. To do it, I removed the climate control unit from underneath the stereo. When I put it back together, the climate control unit doesn't work, and the "Service Airbag" warning is up. Any ideas?
Old Jan 12, 2007 | 09:54 PM
Default RE: Climate Control Problem Please Help!
Try having the codes cleared.
Old Jan 12, 2007 | 11:13 PM
bluemotev's Avatar
Can I do it myself with an OBD or do I need a dealer?
Old Jan 13, 2007 | 12:30 AM
Only the Dealer or an Indipendant shop that can read the codes.
Someone on here had the same problem and there was a simple fix but I couldn't find it.
Old Jan 13, 2007 | 05:27 AM
bluemotev's Avatar
OK thanks. Hopefully I can get it figured out. I'll try to get to a dealer this weekend
Old Jan 13, 2007 | 12:28 PM
Have you tried disconnecting the battery for a few?
If not disconnect it.
Then connect the + and - cables together for 5 minutes. That will discharge all the computers.(That is only touch the cables together. Not jump across the battery)
Then try to connect and see if it works.
Old Jan 13, 2007 | 04:31 PM
bluemotev's Avatar
Nope - haven't tried that yet. Will do right now, let you know...
Old Jan 13, 2007 | 06:11 PM
bluemotev's Avatar
It doesn't seem to have worked... I left it off and the terminals connected for 15 minutes and it didn't clear anything. The SRS alert is still up and the HVAC controls are still non-op. Sigh... This really sucks!
Old Jan 13, 2007 | 07:52 PM
Yes it does Sorry that didn't work.
Have the Dealer clear the codes.
I wish I could find that post. It was an easy fix. The Dealer wanted to replace the module on that car and it wasn't the problem but I forget what was.
Old Jan 13, 2007 | 10:39 PM
bluemotev's Avatar
I really really hope you can find the post/info, cause that's the only next step I can think of. I really don't want to spend the $$.
Old Jan 15, 2007 | 08:21 PM
I will try to keep searching.
Old Feb 4, 2014 | 04:16 AM
ingydrummer's Avatar
So TECH, did you ever find out what that easy fix was for the problems with the climate control and SRS warning? I have been reading about this on here in dozens of threads and nothing?
Old Feb 23, 2014 | 10:09 PM
Tedwardward's Avatar
I have the same exact problem right now with my 2002 S60. What was the solution to the problem?
cheesecake
Aug 8, 2009 07:11 AM
joshuare
Aug 15, 2008 07:18 PM
DBLD
Sep 29, 2006 09:07 PM
jfikentscher
May 31, 2006 09:58 PM
