Coolant Issues HELP!
Old 05-24-2011 | 08:57 AM
igc0408's Avatar
Default Coolant Issues HELP!
I have a '03 s80 2.5 T. About 2 weeks ago, I had a message that said the coolant was low, stop engine, which I did and added coolant. Within an hour, my car was smoking and all the coolant had drained out in the parking lot. I took it to the mechanic and they said it was due to a cracked reservoir which I had replaced. A week later after an hour and a half drive, I stop my car and again it starts smoking and dumped out the coolant. I returned to the mechanic and they said it was just a hose clamp that came loose. They fixed it and as soon as I got home, the same thing happened...coolant dumped out, smoke, over heating. Any ideas? is this a head gasket issue or possibly that the clamp just came undone again??
Old 05-24-2011 | 04:29 PM
birdman_s80's Avatar
It might be the little plastic elbow inside the timing belt cover. Search the forums about it some posts have pictures.
Old 05-25-2011 | 07:38 PM
tony1963's Avatar
You've probably roasted the cylinder head by now.
Old 05-25-2011 | 11:10 PM
volvoguy2323's Avatar
Banned
A bad head gasket does not make a car over heat...a stuck thermostat is most likely your cause...or bad radiator. But if it shoots up real FAST it's a stuck thermostat. The only time a car will overheat from a broken head gasket is when all the coolant leaks out....careful or you will blow your head gasket from so much overheating.
cmayo313
03-18-2011 01:09 PM
Ahmed
08-30-2009 02:58 PM
timk
11-16-2007 09:33 PM
