coolant leak?
Old Nov 6, 2006 | 05:28 PM
heathrlee's Avatar
Default coolant leak?
hi.
i bought my 2000 s80 turbo in august, and it since then i've had to fill my coolant three times. i'm wondering if this is normal for this car or if i should get it checked for a leak. i'm thinking there must be a leak because it is getting to be less time between having to fill it each time. help!
Old Nov 8, 2006 | 08:58 PM
Default RE: coolant leak?
Have it checked for a leak.
Old Nov 8, 2006 | 11:58 PM
S80NIGHTMARE's Avatar
im having the same problem i was told a common area are the two heat hoses comming from the inside of the car to the engine i had a leak on the driver side one and also lucky me on the bottom of the tank. you might want to check those out.
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
