Coolant warning
Old Dec 8, 2005 | 05:30 PM
simon_mahoney's Avatar
Default Coolant warning
I am continually getting "coolant low level, stop ASAP" and "coolant low level stop engine" warnings. The coolant level is always between the min and max lines. The temperature never moves from mid position. The local Volvo dealer cannot find a problem. any ideas?
Old Dec 9, 2005 | 12:09 AM
Default RE: Coolant warning
Did they install a new sensor?
Old Dec 9, 2005 | 01:07 AM
no they didn't change the sensor. I also have an emission system service message, that the dealer cannot resolve. Culd this be a sensor problem as well.
Old Dec 9, 2005 | 03:27 AM
gordon368's Avatar
funny story,
One time my old car the 2001 s40, was accelerating by it self, like my foot was not on the gas pedal and it wud accelerate on it's OWN!!!!! And it was having a very difficult start, and when u started it it would cough ALOT and the meter for the engine heat would move quickly to the top. I dragged it into the gas station got my inspection stick (hahaha) then minutes later my coolant sprayed everywhere, it was smoking like crazy......THe solution was a new gasket and thermostat and a new sensor...
Old Dec 9, 2005 | 08:33 PM
ORIGINAL: simon_mahoney
Im supprised they didnt change the sensor in the coolant bottle. That is what tells the computer if it is low or not.
Also which codes did they pull for the emmissions system?
What did they do to it?
Old Dec 9, 2005 | 09:57 PM
On the emmissions problem they told me there were no codes relevant to this. Only a code related to "camshaft position sensor" which was probably due to low oil.
Old Dec 10, 2005 | 12:03 AM
If the message was there that means there was codes. Look on your receipt and see if they put the codes on there. Most dealers will do that.
Old Dec 10, 2005 | 11:09 AM
RTRAVISGLASS's Avatar
1999 S80 T6 owner here.. just turned 107K Same coolant warning light problem which occured more frequently in summer months than winter months. Warning went away when small amount of water was added to overflow tank. Diagnosis from dealer: they've been seeing the overflow tanks get small leaks in them as they age. Fix: new tank, new sensor $150.00
checksix
Aug 2, 2009 06:06 PM
golds80t6
Jan 8, 2008 10:50 PM
jimatqsi
Aug 26, 2007 01:13 PM
simon_mahoney
Jul 30, 2006 11:56 AM
dc_slim
Dec 14, 2005 06:25 AM
