Crank, No Start After Removing Battery
Old Jul 20, 2014 | 09:35 PM
muddblood's Avatar
Default Crank, No Start After Removing Battery
Hello all. I have a 00 Volvo S80 T6. The biggest issue right now is it won't start after I removed the battery and charged it over night at 2 amps. I put the battey in today, and it cranks very strong, but will not start. It started without issues before the battey died.
I have tried the following:
- Unlock the drivers door with the key.
- Unlock all doors with the key.
- Disconnected the battey, placed the ignition switch in the 2 position, connected the battey.
- Cycle the ignition switch on and off 3-4 times.
- Placed one key out of the car, cranked car with other key.
Car still will not start. As far as I can tell, both keys are master keys (no valet). Any other suggestions? I read that the alarm module battery being bad could cause this, but it started before the car battery died.
Old Jul 25, 2014 | 05:59 PM
muddblood's Avatar
Well, I got it started. I ended up removing both battery cables, touching the cables together for 5+ seconds, reconnecting the battery, locking and unlocking the driver's door with the key 5 times, placing ONE key (other key was 7' away) in the ignition, waiting for a second or two, then it fired right up. Did the door lock and ignition with the other key, an both keys now work to start the car.
Old Sep 9, 2014 | 01:51 AM
thehabitualcriminal's Avatar
Sounds better than the other suggestion to smack it on the side and say eehhhhh, like the fonze. My wife's 99 has begun doing something similar. I will bookmark this suggestion.
Terminator5
1998-2000 model year V70
May 12, 2015 08:05 PM
Lavid2002
May 26, 2011 06:00 AM
Lavid2002
Mar 1, 2011 06:20 PM
datderboy216
May 22, 2010 06:38 PM
rpsail7cs
Sep 25, 2009 09:12 AM
