crank sensor i think
Old Apr 22, 2011 | 05:27 PM
jonnyvolvo79's Avatar
Talking crank sensor i think
just bought a 2000 volvo s80 t6 and the turbos were blown so i had them replaced
it ran great for two days and then it died and hasnt started in two weeks
NO SPARK
timing belt is practically new and is in good shape
Im thinkin its the crankshaft position sensor. i bought one today but cant find it anywhere. I check all around the balancer even pulled off the timing cover. nothing i just red somthing that said it was on the driver side under the upper mount is that right? do you think this will fix the problem?
Thanks for all your help
Old Apr 24, 2011 | 08:06 AM
The crank sensor is on the back of the motor. Like where the transmission meets the motor. It is under the hood by the top of the transmission.
Is any fuses blown?
Old Apr 30, 2011 | 09:28 AM
no their where a few missing but I relaced all of them
Old Apr 30, 2011 | 09:31 AM
Is any fuses blown?
yes all fuses are cuurently good and thanks i replace the crank sensor and the cam sensor per the that was pulled from the car 0342 cam sensor low signal bank 1 but still no luck
Old Apr 30, 2011 | 09:49 AM
Check all the ground wires as well. Does the tach jump when you try to start it?
Old Apr 30, 2011 | 09:55 AM
no it stays at about 300 rpms when cranking
Old Apr 30, 2011 | 10:02 AM
Ok I aksed because sometimes the speed sensor and power wire are to close and they block each other.
Old Apr 30, 2011 | 10:25 AM
oh idefinitly understand and i appreciate all your advice could it be the coil packs went all at ounce you think
Gullfisk
Oct 11, 2022 10:18 PM
jonqu
Sep 4, 2013 12:45 PM
Gullfisk
Feb 16, 2012 04:24 PM
datderboy216
May 22, 2010 06:38 PM
rpsail7cs
Sep 25, 2009 09:12 AM
