Emission/// Check engine
Old Jan 29, 2006 | 07:41 PM
jaz's Avatar
jaz
Default Emission/// Check engine
My info system reads emission system required. I had someone check it for me and the reading was code P0455. Evap Emissons control system leak.
Old Jan 29, 2006 | 08:12 PM
Default RE: Emission/// Check engine
Is the gas cap loose?
Or did you fuel up with the car running?
Old Feb 25, 2006 | 12:59 AM
jaz's Avatar
jaz
Hey tech. Yes, one time I put gas in the car while it was running. I went today 2/24/06 to my volvo guy and he said that it is my Oxgen senser. And that I need four of them. And they cost about for $200 to $250 for one.
One more question. Is there any thing special to do when you ghang front breaks? Thanks
Old Feb 25, 2006 | 01:05 AM
The front brakes are easy and straight foward to do. The Hardest part of the job is putting the spring back on after the caliper is bolted back on.
You will need a 7mm Allen wrench,a big pair of channel locks or a C clamp to compress the piston.
To install the spring I install one side then try to get the other side started and use a pair of pliers and put that side under the caliper. Then use a screwdriver to put the middle section behind the caliper.
Old Feb 27, 2006 | 02:18 AM
jaz's Avatar
jaz
Thanks Tech's for the help. on the brakes. But what do you think about the last post on emission.
Old Feb 27, 2006 | 02:44 AM
Try to find out from him which side is bad. I would do the both for the side the codes says is bad.
I think he might be trying to sell you all 4 to cover his A**.
Old Mar 18, 2006 | 01:23 PM
jaz's Avatar
jaz
Thanks alot Tech. Your the MAN bro.
Old Apr 29, 2006 | 02:52 PM
jaz's Avatar
jaz
Hey what's up Tech? I had all 4 oxgen senser changed and now I have more problems. the car runs worse than before.The check engine I is on and it's saying drive slow service ergent. My mechanic says it that metel box under the exhaust manifold, I foregot the name of the part. what do you think. THANKS FOR THE HELP!
PS. Is there anyone that has that problem?
Old Apr 29, 2006 | 05:46 PM
Electronic Throttle body??
If so then it should still be under Warranty. They extended it to 10 years 200,000 miles.
Old May 2, 2006 | 08:09 PM
jaz's Avatar
jaz
What's up tech? Thanks for the info.But do I still qualify for the warranty if I brought thr car used. (1999 s80) NY. And if not what will a job like that cost at the dealer. My mechanic said that if he did it I will still have to take it to the dealer so they can do the software. And they might not want to do that THANKS TECH!!!!!!!!!........
Old May 2, 2006 | 09:26 PM
Yes you should still be covered no problem.
That warranty should go with the car and not the owner.
The warranty was brought on by Lawsuits.
Old May 3, 2006 | 01:02 AM
jaz's Avatar
jaz
Thanks tech. I will try and see if I can get it
robingichuhi
Feb 22, 2017 04:34 PM
AronS40
Jan 17, 2013 10:11 AM
simon_mahoney
Aug 1, 2006 12:00 AM
tkruid
Nov 17, 2004 10:45 PM
VolvoNewbie
Nov 7, 2004 10:21 PM
