Headlight
Old Feb 9, 2007 | 09:24 PM
gordon368's Avatar
Default Headlight
My headlight does not work, driver side... I tried a bulb change and checked the fuses and none of that worked. Is there a relay to check out?
Just the driver side is out....
thanks
Old Feb 10, 2007 | 10:31 AM
Default RE: Headlight
Do you have power at the headlight assembly?
I have seen the wiring inside the headlight short out.
Old Feb 11, 2007 | 05:50 AM
gordon368's Avatar
Does not look like I have power.... If I dont have power what do I do? Im gonna check with the meter that reads if there is voltage there... That headlight occasionally gets foggy, could water have damaged it?
Old Feb 11, 2007 | 11:50 AM
Maybe water damaged it.
You checked all fuses?
There should be a seperate one for that headlight.
Old Feb 12, 2007 | 02:31 AM
gordon368's Avatar
yah that fuse looks good, funny thing i noticed is the high beams work fine on each side. Looks like The wiring will have to change? i dont know if this changes anything.... "bulb out dipped beam" message is on too...
Old Feb 12, 2007 | 02:33 PM
gordon368's Avatar
hahah, I just realized that I think I was swapping the high beam bulb instead of the low beam bulb, I think I changed the one that is closer to the center grille...lol I feel stupid if i did that lmao
slynchy
Apr 4, 2016 07:37 AM
danni
Sep 17, 2013 11:56 AM
Peter1234
Nov 23, 2010 01:19 PM
kevinmcgrath
Nov 24, 2004 06:57 PM
scoutdavis
Sep 22, 2004 08:49 PM
