Help again
Old Jan 8, 2006 | 05:13 PM
jaz's Avatar
jaz
Default Help again
The harness inside my door was weged in between the bracket and one of the arms that lifts the window. One of the wire's had rubbed though. I think it shorted someting out. The fuse's are good. Other than the fuse box under the hood is there some were else that can be check. THanks
Old Jan 8, 2006 | 11:22 PM
Default RE: Help again
It might have burned out the Door Module (Window switch)
Old Jan 10, 2006 | 08:38 PM
jaz's Avatar
jaz
Thanks Tech. Is the door module window switch the driver door switch. Second let me add that my front two door locks dose not work with my remote alarm.
Old Jan 10, 2006 | 11:28 PM
Yes the module is the window switch. That might also affect the door locks.
Old Jan 11, 2006 | 07:46 PM
jaz's Avatar
jaz
Thanks alot bro. I will letyou know if I need more help. I took it to a volvo shop and he said that he need to trace the problem.
Old Jan 29, 2006 | 07:26 PM
jaz's Avatar
jaz
Thanks for all the window help guys the problem was some modules. So they say.
Old Feb 10, 2006 | 01:12 AM
JCVolvoS80's Avatar
The problem they tell you is going to be the most expensive...because they have to make money somehow! I always ask for the broken parts back when they are fixed...thats what I did with my Ignition switch.
Old Feb 25, 2006 | 12:42 AM
jaz's Avatar
jaz
Thanks for the feed back JC.
cioara
1998-2000 model year V70
Sep 24, 2014 07:25 AM
crystalfleet
Jan 16, 2008 07:30 PM
JavlaBil
Oct 9, 2007 08:35 AM
mikhailarey
Jun 19, 2005 10:56 PM
jupslam
Apr 7, 2004 02:37 PM
