Help wanted: Replacing PS Pump
Old Jan 5, 2010 | 08:43 AM
brennanpersonal's Avatar
Default Help wanted: Replacing PS Pump
My 2000 S 80 Power Steering Pump is making a bit of noise and now on cold mornings the belt starting to squeal. I am going to replace it. I am not an expert mechanic but I have done some repairs, like removing and re installing my ABS sensor, installing a new headlight, and stuff like that. Can anyone give me the PS Pump replacement procedure
Old Jan 5, 2010 | 12:45 PM
harryhood's Avatar
Before changing the pump I'd make sure it's not just a loose or worn/dirty belt.
Old Jan 5, 2010 | 09:54 PM
Default ps Pump
No, It's the pump. Been groaning for 3 years.
Old Jan 5, 2010 | 10:07 PM
It is real easy. There is only 3 or 4 screws after removing the belt and it is off.
Also did you make sure the inside of the bottle is not bad causing air into the bottle causing the noise?
Old Jan 6, 2010 | 08:14 AM
Default PS Reply to Tech
Thanks for your input.
You wanna expand on that?
Screws?
Also, any bleeding of the lines nessessary or any other complications.
Or, do I just remove it, reattach the hose, fill it up with PS fluid and drive away?
Mike
Old Jan 6, 2010 | 08:21 PM
The screws are behind the pulley. Once the belt is off you go through the hole in the pulley and get to the screws. They are a 12MM screw.
After installing the new one start the car and run it for a few and top up as needed. Also turn the steering wheel from side to side about 8 times or so.
Old Jan 7, 2010 | 10:24 AM
Default PS Pump
Ok, Harry I got it.
The used pump came today and I will put it in next week when it warms up.
The screws are bolts.
Regards,
Mike
Dieterly
May 13, 2015 08:54 AM
s40volvo
Sep 16, 2011 06:17 AM
laurawoc
Sep 14, 2010 01:31 PM
IdleTime
May 29, 2008 04:01 PM
mason_200
Apr 18, 2007 08:21 PM
