new transmission issue
Old Apr 18, 2007 | 10:42 PM
ghostriderT6's Avatar
Default new transmission issue
I have a 2000 s80 T6. Transmission froze at 112k and was deemed worthless by the dealership. The cost was around 5000 dollars to replace it. I opted to buy a used transmission and put it in myself with the help of my mechanically inclined brother. Risky, yes...since it is one of the most difficult transmissions in the world to replace. But we got it done. It drives decent, yet not good. It shifts VERY slowly under normal acceleration and under harder acceleration it sometimes wont shift at all or it will shift (with a loud clunk) way late. Using the Tiptronic (autostick) method of shifting works a little better since i control the shifting manually, but it's still very sluggish. I added some transmission fluid and transmission doctor to seal it up just in case of leaks. Any suggestions? The car works pretty good once it's at cruising speed, it's just not consistent and from 1st to 2nd and 2nd to 3rd is when all the problems occur. Will this wear off? or is there something i can do to help it out
Old Apr 21, 2007 | 06:53 AM
v70 2.4t's Avatar
Default RE: new transmission issue
I would say you need a software upgrade, dealer will have to do it...
tranny out of another car is like attatching a monkey's arm to a human,
you will need the most current software installed.
Good luck
v70 2.4t
acpenn
Feb 25, 2014 06:50 PM
Earthfromorbit
Jun 15, 2011 03:14 PM
JRWilding
Nov 1, 2006 01:59 PM
Psaboic
Sep 18, 2006 08:35 PM
themeat
Oct 12, 2005 12:37 AM
