keeyless entry remote
I figured out the probelm last evening. The verticle contact which touches the outer ring of the battery was bent down and wasn't making contact with the battery. It was flat to the printed circuit board. I thought it was to be that way. My mistake. I realized that something was wrong what I rigged up the battery to make the correct contact and the remote worked fine. So I bent the positive contact vertical again. Now being very weak, I am concerned that this may break. I will use a small amount of electrical solder this evening on the base of the positive contact to support this. Should work.
Thanks tech.....
Thanks tech.....
