Looking to Buy a 2000 Volvo S80 TT
Old Mar 5, 2010 | 09:10 AM
jdp6000's Avatar
Default Looking to Buy a 2000 Volvo S80 TT
I thinking about buying a Twin Turbo. It has about 150,000 miles on it. I can get it pretty cheap. Is this a good car? Anything to watch for?
Jim
Old Mar 5, 2010 | 11:16 AM
jlewisinsyr's Avatar
The transmission is probably the weakest link in the '00 and are probably the most common complaint of drivers who own one.
Old Mar 5, 2010 | 11:52 AM
NoLifeTilBoost's Avatar
How cheap is cheap? If you are one to wrench on your own cars, then its a car worth considering. If not, I'd stay away as the maintenance costs will be pretty nasty if you are having someone else do the work.
Depending on how long you plan keeping it for, budget on possibly needing to replace the following if the PO has not, some of these apply to all cars of this age/mileage of course:
ETM (The recall was a software fix, the hardware issue still applies and its only a matter of time before it fails) $600 (for aftermarket improved model)+labor
4 O2 sensors (close to $500 + fitting)
2x Cats
Transmission rebuild ($1800+). Its not so much that the tranny is bad, moreso that its not designed to handle the torque that that T6 puts out throughout its rev range. Im not aware of any hadware changes that were made after 2000.
Suspension components: control arms, bushings
PCV system (only <$200 in parts, but 4hrs of labor).
Ticking lifters: The orings get hard and cause a bad seal, loosing oil pressure $20 in parts but 2-3hrs of labor. This issue can escalate to a dangerous loss of oil pressure however and that will cost $$$$
Turbo oil return pipe leaks, cheap to fix.
As with any turbo car, maintenance history is imporant if you can get it, check for signs of sludge or general neglect.
Check the transmission fluid level and condition, the dipstick is by the brake fluid resovoir.
When the car is warm, pull the oil dipstick and see if there is smoke coming from there, if there is the PCV will likely need service. Otherwise the pressure might build up to a point where it blows out cam and crank seals.
Dont get me wrong, they are a nice car and the T6 motor is really nice. Just be sure you know what you are getting into
Old Mar 5, 2010 | 12:54 PM
Post 2001, a different transmission was used, so the issue is diminished.
Old Mar 5, 2010 | 01:39 PM
What was it? A non GM procured unit I guess?
Old Mar 5, 2010 | 02:54 PM
I am not sure off the top of my head who makes the 2002+ transmissions, but they are not the same GM low torque transmissions in the pre 2002.
Old Mar 5, 2010 | 03:55 PM
jdp6000's Avatar
2x Cats
Probably about $500. Its been hit on the front. From what I can see its clean but will need 2 fenders and the front bumper cover.
Jim
Old Mar 5, 2010 | 03:59 PM
Hell for $500 if you are OK with the stuff I posted and it seems otherwise OK, go for it.
Old Mar 5, 2010 | 09:38 PM
jdp6000's Avatar
I am having someone look at it this weekend. So long as there is no structural damage i think I will pick it up.
I see if I can get some pic's.
Thanks for the Feedback.
Jim
Old Mar 6, 2010 | 07:31 AM
andrei3333's Avatar
steering rack leak, ive seen it posted many times on other site and have had mine rebuilt as well, to add to the listed issues above
i did not have any of the above issueson my 99 though, with 210.000 KM on it now except 2 of 4 oxygen sensors failed (those were a pain to replace)
Old Mar 13, 2010 | 05:53 PM
jdp6000's Avatar
Looks like I will be picking up this car next week. I had to boost it to start it. did it off the battery. I think that is a no-no. At least it is on my XC70.
Anyway I noticed the sunroof does not open...no power, the dome lights don't go on and the garage door opener buttons do not light up? is there a common fuse for all these items? Or is it a programming issue?
Jim
pt80chip
Sep 2, 2014 12:25 AM
JCoder
Oct 31, 2009 05:08 PM
JurassicJet
Oct 3, 2009 09:23 PM
Michael7272
Jan 10, 2009 01:47 PM
zirconx
Aug 1, 2008 12:58 AM
